04-23-2013 09:05 AM
i use LabWindows and Vision 2010 with IMAQdx vers. 3.7.
I need to control the registry setting of a Basler Racer camera with frame grabber PCIe-1429.
The acquisition through MAX works fine, but i have problem when open the camera in CVi using GenICam instructions.
When i call the instruction IMAQdxOpenCamera, i receive the error 0x80004005 (-2417467259), that is not listed in the errorr code of the IMAQdx.
Anyone had the same problem?
Thank you in advance
04-29-2013 07:33 AM
are you able to run CVI Grab example?
How is the camera detected in Windows Device Manager?
Try to reinstall Vision Acquisition Software.
I hope this helps!
Bye,
Licia
