I am running two devices, a Bertan high voltage source and a Hewlett Packard multimeter, with an GPIB-ENET/100 setup, and the Hewlett is giving an error when I address a command to the Bertan. What can I do to determine the problem?
If it's an instrument error the manual will be helpful. For GPIB communication refer, GPIB Error Codes and Common Solutions . I hope you have the latest GPIB driver available from http://www.ni.com/support/gpib/versions.htm. If you don't, follow the steps from www.ni.com/support/install
