LabWindows/CVI
I am need to create an exact duplicate of an excel worksheet in the same workbook.
I need to copy an existing worksheet in the same workbook.
I am trying to use a function provided by NI in excel2000.c:
HRESULT CVIFUNC Excel_WorksheetCopy (CAObjHandle objectHandle,
ERRORINFO *errorInfo, VARIANT before,
VARIANT after)
HRESULT __result;
unsigned int __paramTypes[] = {CAVT_VARIANT, CAVT_VARIANT};
__result = CA_MethodInvoke (objectHandle, errorInfo, 0x227, CAVT_EMPTY,
NULL, 2, __paramTypes, before, after);
return __result;
...but it is copying the sheet to a new workbook. So i am either using the wrong function , or I am using this fu
nction incorrectly. SO if someone could point out the right function, or how to use this function proeperly, it would be apprecited.
Message 1 of 9
(4,811 Views)
hello
This will happen if you leave both the "before" and after" parameters as CA_DEFAULT_VAL. You need to pass the handle to one of the sheets as follows, convert the objHandle to variant, and pass that to the "before" or "after" parameters, but not both
error1 = CA_VariantSetObjHandle (&sheet1, ExcelWorksheetHandle, CAVT_DISPATCH);
error1 = Excel_WorksheetCopy (ExcelWorksheetHandle, NULL,CA_DEFAULT_VAL, sheet1);
This should do the trick
Bilal Durrani
NI
Bilal Durrani
NI
Message 2 of 9
(4,811 Views)
Thank you for your response. I think that will do the job. However, i can't seem to locate the CA_VariantSetObjHandle function. There is a CA_VariantGetObjHandle and a CA_VariantHasObjHandle though. I am running CVI v5.5. Your continued assistance would be appreciated.
Message 3 of 9
(4,811 Views)
Open up a C file,press CTRL+Shift+P and search for that function, it should be there in the activeX library under Variant related Functions >> Assigning values to variants
Bilal
Bilal Durrani
NI
Message 4 of 9
(4,811 Views)
I have searched for CA_VariantSetObjHandle using the method you prescribed, and have come up empty. CA_VariantGetObjHandle & CA_VariantHasObjHandle both turn up in the search.
Message 5 of 9
(4,811 Views)
Its definetly not there in CVI 5.5, I think this was added when some more activex features were introduced in CVI 6. But try the following:
//convert handle to dispatch
error1 = CA_GetDispatchFromObjHandle(ExcelWorksheetHandle, &testing1);
//Convert disptach to variant
error1 = CA_VariantSetDispatch (&sheet1, testing1);
It should have the same effect, just not as straightforward.
Bilal Durrani
NI
Message 6 of 9
(4,811 Views)
That did the trick.
Thank you for your assistance.
Its greatly appreciated
Message 7 of 9
(4,811 Views)
I need to make a copy of the worksheet so I can use for pasting to another workbook (or to the same worksheet) in the same Excel application.
But, I am stuck with the following code.  I can't seem to get a copy of the worksheet.  Could you please show me how you did it or
check what I did wrong.  Below are my code.
if (FileSelectPopup ("", "Sheet1.xls", "Sheet1.xls", "", VAL_LOAD_BUTTON, 0, 0, 1, 0, excelFileName))
  SetCtrlAttribute (panelHandle, PANEL_CLOSEDATABUTTON, ATTR_DIMMED, 0);
  SetCtrlAttribute (panelHandle, PANEL_OPENDATABUTTON, ATTR_DIMMED, 1);
  //Create Excel.Application instance
  errStatus = Excel_NewApp (NULL, 1, LOCALE_NEUTRAL, 0, &excelAppHandle);
  //Make Excel visible
  errStatus = Excel_SetProperty (excelAppHandle, NULL, Excel_AppVisible, CAVT_BOOL,   VTRUE);
  //Do not display alert when document is closed without saving
  errStatus = Excel_SetProperty (excelAppHandle, NULL, Excel_AppDisplayAlerts,   CAVT_BOOL, VFALSE);
  //Acess Work books handle and open the selected file.
  errStatus = Excel_GetProperty (excelAppHandle, NULL, Excel_AppWorkbooks, CAVT_OBJHANDLE,  &excelWorkbooksHandle);
  errStatus = Excel_WorkbooksOpen (excelWorkbooksHandle, NULL, excelFileName,
CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,&excelWorkSheetHandle);
  //Copy WorkSheet
  errStatus = CA_VariantSetObjHandle (&Sheet1, excelWorkSheetHandle, CAVT_DISPATCH);
  errStatus = Excel_WorksheetCopy (excelWorkSheetHandle, NULL,CA_DEFAULT_VAL, Sheet1);
  //Discard unwanted handle  CA_DiscardObjHandle (excelWorkSheetHandle);
CK301
Message 8 of 9
(3,948 Views)
ACNI
You will probably want to start a new thread. The original thread is 7 + years old. Old threads usually don't get as much attention even though they get bumped to the top of the forum. Always make a new post for a different problem (even if related to this topic). My 2 cents.
Greg
Message 9 of 9
(3,927 Views)
