LabWindows/CVI
How to realize the calculation of string Formula expression
There are functions to implement in LABVIEW, but I didn't find such a function in cvi.
I would like to ask you how to achieve it.
(1,222 Views)
There is nothing like a formula parser and evaluator in CVI, the alternatives are to write your own code or to use an external library.
I have never had the need for such a library so I cannot give you a working solution. Nevertheless, a quick Google search resulted in this library that seems promising. I can imagine there are other possibly better alternatives out there.
Or, if you master the language, you could write a DLL in LabVIEW and call it in CVI.
(1,186 Views)
Thank you for your reply. I will try the method you suggested
(1,171 Views)
I also wrote a solution in pure CVI code, which uses reverse notation and is simple to integrate to a program: https://www.gdargaud.net/Hack/SourceCode.html#PostfixEval
It does doubles and booleans.
(1,139 Views)
