LabWindows/CVI
How to read HBM amplifier values in CVI
Hello Everyone,
I want to read in CVI the HBM sensor values. Could anyone guide me how i can do it.
Thanks in advance.
(3,440 Views)
Which type of sensor are you trying to interface to? We have used several HMB devices and I have seen many different output types: voltage, current and even frequency signals! If the output is quite particular (like the frequency output of a T10F) HMB supplies conditioning modules that output a voltage signal.
Once the output signal is defined, you can select a variety of acquisition deviced to use to read it.
(3,424 Views)
Thanks for reply
i am using pressure sensors and the output is voltage. The sensor is connected to MX440A amplifier, and this amplifier is connected to PC via Ethernet cable.
So how can i read these sensors values which are connected to this amplifier in a CVI code.
(3,417 Views)
I was intending to directly connect your instrument analog output to a DAQ device: your configuration is a completely different scenario.
I have no experience with MX amplifiers, but from what I have read in HMB site you will need to develop your program relying on the libraries released from HMB. The problem here is I have seen mentioned C++ and other languages / frameworks but not C. I suppose you can ask HMB whether their common API framework can be addressed from a C environment like CVI, hopefully they already have some experience with this.
(3,389 Views)
Ya even i saw that the API is for C# but nothing mentioned for C, I have asked HBM for it. Lets see what reply i get from them
(3,385 Views)
