LabWindows/CVI
How to acquire from various AI channels simultaneously with a different range for each one?
In LabView I have found some examples but in C there isn't seem to be any.
(4,703 Views)
One possibility is to create virtual channel in MAX, each with the appropriate range, and then programmatically add the channels to the acquisition task with DAQmxAddGlobalChansToTask
(4,693 Views)
Accepted by topic author Franchesco
Or you can add channels one by one with individual instructions: the follwing code compile and runs with no errors on a vitual daq device:
err = DAQmxCreateTask ("", &taskH);
err = DAQmxCreateAIVoltageChan (taskH, "Dev1/ai0", "AI0", DAQmx_Val_Cfg_Default, -5.0, 5.0, DAQmx_Val_Volts, "");
err = DAQmxCreateAIVoltageChan (taskH, "Dev1/ai1", "AI1", DAQmx_Val_Cfg_Default, -10.0, 10.0, DAQmx_Val_Volts, "");
DAQmxStartTask (taskH);
err = DAQmxReadAnalogF64 (taskH, 5, 10.0, DAQmx_Val_GroupByChannel, val, 10, &read, 0);
DAQmxClearTask (taskH);
(4,690 Views)
