LabWindows/CVI
How do I link with ws2_32 or winsock?
Currently, I'm reinstalling based upon this post.  This didn't work... Our IT does not allow connections to the internet.  I cannot activate correctly, though I did install a off-network node-locked license.  The installer does not seem to use it.  Now, I cannot even run LabWindows.
Previously, I couldn't seem to figure out how to link to Winsock.  I went into the bin directory where the other libs are located but my MSVC directory is empty.  Where are those located?  I have a full version license, but my Windows HKLM...type == Eval.  Also, my "eval" license is over.  SO, I'm not sure whether this is a licensing issue, an ignorance issue with adding windows libs to the project or an install issue.
If you have any light to illuminate my way, please shine on.
Andy
(155 Views)
Installing a second time...  Is there a DIFFERENT iso image to download?  I found the base,full and installed it.  Anyone?
(137 Views)
Accepted by topic author MAKennedy
Three points:
  • We have volume licensing which makes the install even more interesting.  The bottom line, however, is to delete everything out of your license directory except for your company's provide license file.
  • Not sure if NI installed this or if it came from another install that I've done, but the library files are located at:
C:\Program Files (x86)\Windows Kits\8.1\Lib\winv6.3\um\x86
  • If you have many files within your project tree, the container "lib" will off the screen at the bottom.  You must scroll down and add in the libraries you need.
(106 Views)
