LabWindows/CVI
How can I kill all received mouse events after system processing?
I must program a test sequence (communicate with GPIB-devices an so on). The test sequence must be started with a click on a command button.
If the user clicks on this button while test sequence is running, the test starts all over after sequence is finished.
How can I kill all user activity (mouse and kexboard)?
I tryed it with SetInputMode and SetCtrlAttribute (dimmed). But I have still the same problem.
I'm using CVI 6.0.
Thanks for your help.
(3,404 Views)
I have the same problem
So I set button attribute with SetCtrlAttribute() to dimmed
and after this function call you need to call ProcessDrawEvents() and your button status will be updated.
(3,382 Views)
you can SetPanelAttribute to dim too.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,370 Views)
