LabWindows/CVI
Hi, I am using DLL generated from CVI involving a dotnet dll. The execution of the dll returns a -6579 error. DotNet DLL is in the same directory as the working directory.  Which may be the problem please?
(3,184 Views)
Hi NBChaaben,
Could you elaborate on what you mean by "working directory"? This error means CVI could not load the specified assembly. It could be a corrupt dll issue.
Can you run a simple application running this .net dll? If not, then there is probably something wrong with your dll.  I've included an article on using DLLs in CVI.
http://zone.ni.com/reference/en-XX/help/370051M-01/cvi/programmerref/rules_for_using_dll_files/
Hope this helps.
Josh L.
(3,172 Views)
