LabWindows/CVI
Help: what is cviauto.h use for in CVI?
can anyone advice. just to understand
(3,729 Views)
Hi chris_chua,
The header file (cviauto.h) is used for the CVI Automation Library which allows for the use of ActiveX. The functions typically follow the prototype of "CA_functionname (param 1, param, 2, etc.)". It also is used when accessing the TestStand API in CVI.
ActiveX Library Help List
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/libref/cviactivex_automation_libfunctiontree/
Note that if you select any of these functions and read the online help they will list:
Additional Information
Library: ActiveX Library
Include file: cviauto.h
Also an example of using cviauto.h for the TestStand API:
http://www.ni.com/white-paper/14378/en
- FCTesting
(3,721 Views)
