LabWindows/CVI
GetPlotAttribute and SetPlotAttribute of a Rectangel?
how can i use GetPlotAttribute to obtain the (double x1, double y1, double x2, double y2) of a Rectangel which is plotted by PlotRectangle. And then use SetPlotAttribute to reset them or replot this rectangel when the resetting is impossible?
any suggestions are appreciated!
Jiafei Peng
(3,574 Views)
Jiafei,
You can use the PlotPolygon function, which will do the same thing for you as PlotRectangle, then you can use the  ATTR_PLOT_XDATA and ATTR_PLOT_YDATA attributes of GetPlotAttribute to get the x and y data from a plot.
(3,561 Views)
In addition to Dave suggestion, please note that you cannot modify plot data: you will need to always delete previous plot and redraw a new rectangle with updated values.
Message Edited by Roberto Bozzolo on 07-24-2006 08:55 AM
(3,552 Views)
Dave and Roberto,
thank you very much for your suggestions.  I have already succesefully applied PlotPolygon. And it works exactly like required.
because ATTR_PLOT_XDATA and ATTR_PLOT_YDATA  can be obtained easily by GetPlotAttribute and then redraw this Polygon.
Thanks again
sincerely
Jiafei
(3,534 Views)
