11-30-2018 04:27 AM
Maybe this is a stupid question, but is there a way to get the value of a control attribute that has been set in the uir?
I try to explain better with an example.
Solved! Go to Solution.
11-30-2018 05:00 AM
Not so stupid a question!
I could think to a couple alternatives to obtain what you want.You could for example try calling DefaultCtrl and get the attribute value you want. Unfortunately, DefaultCtrl is more aimed to operate on the control value rather than its attributes so this is possibly a dead end. Besides it, should it works you'll have then to restore all modified attributes one by one!
As an alternative, you could load a second instance of the panel in memory and get attributes from the correspondent control in this offline copy. Of course, there is no need to display this panel.
11-30-2018 05:33 AM
Hi vix,
what I do (not for LEDs, but numeric controls) to see if a value has changed is to save the old value before getting the new one:
old_value = current_value;
current_value = GetCtrlVal ();
if .....
(for an explanation of why I am not relying on the EVENT_VAL_CHANGED see here)
You can easily adapt this procedure for your case as well
11-30-2018 07:58 AM
@RobertoBozzolo wrote:
You could for example try calling DefaultCtrl ...
Looking to DefaultCtrl documentation I don't think this is a realistic option, unfortunately.
This seems to be an effective approach "at run time" (I mean, this involves calling a function during execution of the code). This involves reading an uir file from disk to get the information, so I can't estimate the performance (especially with big uir files).
Since the default values for attributes should be known at compile time, I wonder if there is an option to get this info "at compile time" (I mean, through a macro or something like that, that can be evaluated at compile time).
Unless CVI architecture allows changing the values inside the uir without recompiling the executable (I'm not sure if this is possible and/or allowed and/or recommended).
If this is the case, the only way would be "at run time" and so I think the best approach would be another call to LoadPanel.
11-30-2018 08:37 AM
Well, I have never benchmarked calls to LoadPanel so I cannot say anything on that.
A different approach could be to maintain a list in memory of attributes changed and their default value. A structure like this one:
typedef struct { int panelHandle; int controlID; int attribute; int valType; // int, double, char... int iVal; double dVal; char cVal[64] } attrL;
(I very well imagine it can be optimized a lot when actually implementing it)
Every time you change an attribute:
- Look for a record in the list for the given panel/control
- If not existing, create one with the default attribute value
When you restore the attribute to the default:
- Read the default value from the list
- Delete the record afterwards
Not exactly a simple task, but I imagine you are not doing this ten times / sec on dozen of controls, aren't you?
12-03-2018 01:22 AM
I think that the best approach is to call another LoadPanel(), as suggested above.
12-03-2018 03:23 AM
In order to minimize performance issues, the second panel instance could have the same lifespan as the operative one (i.e. be loaded and discarded together with it): normally the memory footprint of a panel is small and you'll have the "shadow panel" ready for access at any time.
