Hi Mark,
From what you've given me so far, it's hard to tell what could cause this. I would try a variety of tests to see if we can narrow down the problem. Is it possible to step thru the Initialization code to see what command it breaks on? Also, you mentioned that it works fine when in its own project, but when you add them to another project, it fails. Have you checked to see if it's the extra code you're inserting that causes the problem? Lastly, these faults usually occur when you're trying to access or allocate memory that you're not supposed to touch. Is there anywhere in your code that you do something of the sort?
Jeremy L.
Jeremy L.
