02-15-2018 01:11 AM - edited 02-15-2018 01:23 AM
Hi All,
I'm using CVI2015 Sp1 and FPGA Interface C API to interact with FPGA module PXIe-7962R. The goal is to transmit and receive data, between 2 predefined channels (one for TX other for RX), using RS485 communication standard that implemented in FPGA.
I followed the NI example about FIFO write/read and created 2 separate functions, 1 for writing data and another for reading.
When writing the data into the DMA fifo I run the following sequence:
NiFpga_WriteFifoU64 (*session, NiFpga_rs485_HostToTargetFifoU64_FIFOIN, fifo_Arr, txNOElements, TIMEOUT_MILISEC, NULL);
NiFpga_AcquireFifoWriteElementsU64 (*session, NiFpga_rs485_HostToTargetFifoU64_FIFOIN, &txElementsAcquired, txNOElements,
TIMEOUT_MILISEC, &stArrTxChannelState[chnNum-1].m_writeElements,
&remainingTxElementsInDMA);
NiFpga_ReleaseFifoElements(*session, NiFpga_rs485_HostToTargetFifoU64_FIFOIN, txNOElements);
The return status of each function is 0. I assume that "write" was performed successfully because the txElementsAcquired is same as tx Number of elements that required to write.
When reading the DMA FIFO I created the following sequence -
NiFpga_ReadFifoU64(*session, NiFpga_rs485_TargetToHostFifoU64_FIFOOUT,
(uint64_t*)rxData, rxNOElements, TIMEOUT_MILISEC, &remainingDMA_RxElements);
NiFpga_AcquireFifoReadElementsU64 (*session, NiFpga_rs485_TargetToHostFifoU64_FIFOOUT,
&rxElements, rxNOElements, TIMEOUT_MILISEC, &stArrRxChannelState[chnNum-1].m_readElements, &remainingDMA_RxElements);
NiFpga_ReleaseFifoElements (*session, NiFpga_rs485_TargetToHostFifoU64_FIFOOUT,
stArrRxChannelState[chnNum-1].m_readElements);
But the return status of NiFpga_ReadFifoU64 is always -50400 - which is timeout. I'm reading the same quantity of elements as were written in a write sequence. After NiFpga_AcquireFifoReadElementsU64 the number of acquired elements is always 0, and remaining elements in DMA is 2.
When running the LV bitfile using LabView interface, the procedure works fine - so I can assume that the bitfile is Ok. .
What do I miss with CVI? I ran the same sequence for other bitfile and seemed to be working.
I there any manual/help files for FIFO functions and how to use them? Because I didn't find any.
Any help is appreciated, thanks in advance. 🙂
02-16-2018 01:32 PM
There is some information in the help documents about these functions.
Did the example program itself run?
Ensure you are not attempting to access FIFO elements after releasing them.
02-18-2018 12:33 AM - edited 02-18-2018 12:36 AM
Hi Dane,
Thanks for your assistance - I've read links that you posted, about READ/WRITE FIFO elements. I followed the example, but didn't run it.
I found a problem in faulty bit arrangement in a data that I pass to FPGA - the firmware was discarding the data upon write, and when I tried to read, there was no data in a FPGA's buffers. So I did some corrections in my software and I was able to receive data and the timeout error disappeared.
In general, as I understand I always have to run the "Release" function, at the END of write/read procedure in order to pass the data from PC host to FPGA_Target, or from FPGA to PC host. But, I can choose either NiFpga_AcquireFifoWriteElements/NiFpga_AcquireFifoReadElements or NiFpga_FifoRead/FifoWrite, to pass the actual data between endpoints (fpga-to-pc pc-to-fpga), depends if I use a local buffer for copying the data into it or receive a buffer pointer, with the data, from Acquire function.
