‎01-29-2010 03:35 PM
I have the problem that in my CAN - Application the following error appears: Dereference of out-of-bounds pointer
The debugger marks the following variable in this text line: if (cmsg_rx[i].id > 384 && cmsg_rx[i].id < 640 && cmsg_rx[i].len <= 😎
This error does not appear always, only sometimes but then in series when trying to run the program. Later, I can start and exit the program without problems.
In one file, the array is defined as CMSG cmsg_rx[2047]; and in the function where the error appeares as extern CMSG cmsg_rx[];
How can I avoid this error?
‎01-30-2010 02:16 AM
‎01-30-2010 03:56 AM
‎01-31-2010 03:39 PM
This is strange: 0 is a valid value for an array index, you should not get this error with such an index.
Are you sure you have this index value when you get the error?
‎01-31-2010 04:13 PM
‎02-02-2010 05:39 AM
‎02-04-2010 06:41 AM
Now, I have new findings in my problem. Because of wondering about the fact thar error only appears ins debug configuration, I deleted the file projectname_dbg.cdb and the directory cvibuild.projectname. From this point on, I can execute the program in debug mode a few times then the error appears again. I do not really understand this. Is it possible that the error is evocated by CVI?
I can shorten my program to the minimum and post the code which makes the error.
Thank you very much for helping me!
‎02-04-2010 07:38 AM - edited ‎02-04-2010 07:40 AM
When you delete those elements, you force the compile to rebuild the debug executable from the source code, whereas if you simply re-run a project in the IDE without modifying anything actual debug executable is used as is. This should be the same as using Build >> Mark project for recompilation menu option.
It is not clear to me why the program runs a few time without -apparently- any modification before the error starts rising: looking at your code could help to find a reason and a solution, if you can narrow down it to a subset that still offers this erratic condition.
One last question: is the byte count in error message always the same of it varies randomly? In the first case I would be prone to look for some repetitive condition that generates the error while in the second I'd start by lookong for some unizialized index or something similar to this.
‎03-26-2010 08:08 PM
Roberto Bozzolo wrote:When you delete those elements, you force the compile to rebuild the debug executable from the source code, whereas if you simply re-run a project in the IDE without modifying anything actual debug executable is used as is. This should be the same as using Build >> Mark project for recompilation menu option.
Message Edited by Roberto Bozzolo on 02-04-2010 02:40 PM
I ran into this problem too and was pulling my hair out. Recompiling everything seems to have worked.
‎04-08-2010 01:37 PM
To me this appears to be a classic example of an uninitialized variable. I know you say you have the index variable initialized but I can't think of anything else that would result in this error.
I personally have a policy of initializing EVERYTHING when I declare it, even if I know I am going to initialize it programmatically right away.
You will never see me write something like:
int i;
it will always be:
int i = 0;
Starting from a known state is invaluable. I cannot tell you how much trouble I had finding initialization problems prior to adopting that practice. It is a very good habit to get into and can save you a lot of hair pulling.
I also highly recommend enabling the following build options:
Detect uninitialized local variables at run-time
Detect unreachable code
Detect unreferenced identifiers
Set Uninitialized local variable detection to Agressive
