07-08-2019 09:16 AM
I'm getting this "Error unable to connect to Label Excel File," each time I try to open the Supervisor exe application. Please help me determine what this Label Excel File is and what I can do to fix this error.
07-09-2019 09:39 AM
Is Supervisor exe an application that you created? Are you using the DSC module? Could you tell us more about your application? Please post a screenshot of the error you are seeing, if possible.
07-09-2019 09:48 AM
No, I did not create the Supervisor exe application. It was created by one our software developer who is no longer with the company. Attach is a photo of the error message.
I'm new to using LabWindows so I'm not sure how to answer you in regards to the DSC module.
Let me know what other information I can provide.
07-10-2019 04:50 PM
From the screenshot it seems like the error is a user generated error. So you'll have to look into your source code to see where this is generated and what it is looking for.
07-10-2019 08:15 PM
My guess is that the exe is looking for an Excel file either to put label contents into, or to read some labels from Excel and use them for a specific purpose. You probably want to research where such an Excel file might fit in to the business workflow, and what folder it traditionally resides in.
And as suggested, search the .c and .h files for ".xls" or ".xlsx" for a really good clue!
