LabWindows/CVI
Error During Installation of a Distribution Kit
While the distribution kit that I have developed will install successfully on Win XP machines,  the kit installer produces the same error message on Win 7-32x machines.  The installer 's error message, occuring the beginning of the load process, is that it "cannot find the file specified", yet it does not display the file's name - space is blank.   Furthemore, as I attempt to install older version distribution kits that were formerly successful, I get the same installation error message on  WIn 7 machines.   I would appreciate any clues.  Are there any event logs that are produced during kit installation that will help identifiy this missing specified file?
The distribution kit was generated with CVI 2009 using a Win 7 -32 bit machine.
(3,195 Views)
Adding more mystery to the distribution kit error discussed above.  I have found that the kit installs successfully on Win 7 x64 machines as well as WinXp x32  machines.  However, the installation error message still exists on Win 7 x32 machines.  On one of these Win 7 x32 machines the error message infers that there is a .dll file  that cannot be found, with no mention or hint as to the file's name.   Again, any tips would be appreciated.
(3,185 Views)
Hi, try to compile the source file from Win 7 32-bit.  What happens when debug the program?
(3,174 Views)
