LabWindows/CVI
Drag Drop with CVI
Did someone implemented drag and drop capbilities with CVI.
I would like to have an application that I can drag files from explorer
to the application window and have the full file name and path appear on
the application panel.
Ori Idan
O. T. Idan LTD. National Instruments Alliance member in ISRAEL
Email: ori@otidan.co.il
Home page: http://www.actcom.co.il/~otidan
Tel: +972-6-6262353 Fax: +972-6-6262405
Things should be made as simple as possible but not simpler
Albert Einstein
(3,635 Views)
Look at this address :
NI Web Support - Example Programs Database: WinTools Instrument Driver
If my memory work fine, there is an example in the Zip file with the Fp.
I have got an other version more complete of the rtf tools that i sended to
you last time. If you want it, ask me...
Bye !
> Ori Idan
72-6-6262405
> Albert Einstein
Sylvain MICHEL - S.N.C.F.
Agence d'Essai Ferroviaire
21, avenue Salvator Allende
94407 Vitry sur Seine CEDEX
CRT Paris Rive Gauche
tel : 41 94 57 / 01 47 18 84 57
email : sylvain.michel@sncf.fr
--- C programmers never die, they are just cast into void... ---
(3,635 Views)
