Did someone implemented drag and drop capbilities with CVI. I would like to have an application that I can drag files from explorer to the application window and have the full file name and path appear on the application panel.
-- Ori Idan O. T. Idan LTD. National Instruments Alliance member in ISRAEL Email: ori@otidan.co.il Home page: http://www.actcom.co.il/~otidan Tel: +972-6-6262353 Fax: +972-6-6262405 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Things should be made as simple as possible but not simpler Albert Einstein ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
Look at this address : NI Web Support - Example Programs Database: WinTools Instrument Driver If my memory work fine, there is an example in the Zip file with the Fp.
I have got an other version more complete of the rtf tools that i sended to you last time. If you want it, ask me...
Bye !
Ori Idan a écrit :
> Did someone implemented drag and drop capbilities with CVI. > I would like to have an application that I can drag files from explorer > to the application window and have the full file name and path appear on > the application panel. > > -- > Ori Idan > O. T. Idan LTD. National Instruments Alliance member in ISRAEL > Email: ori@otidan.co.il > Home page: http://www.actcom.co.il/~otidan > Tel: +972-6-6262353 Fax: +9 72-6-6262405 > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > Things should be made as simple as possible but not simpler > Albert Einstein > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
-- Sylvain MICHEL - S.N.C.F. Agence d'Essai Ferroviaire 21, avenue Salvator Allende 94407 Vitry sur Seine CEDEX CRT Paris Rive Gauche tel : 41 94 57 / 01 47 18 84 57 email : sylvain.michel@sncf.fr --- C programmers never die, they are just cast into void... ---
