LabWindows/CVI
DiscardCtrl causes general protection fault
Hello all,
I just stumbled upon a problem that seems too simple to be true. If I call DiscardCtrl from _that_ control callback, or if I call it from the panel callback without swallowing the even, I get a general protection fault.
Here's an example. To test it, double click on the control and it crashes. If you double click on the panel or use "return 1", no problem:
#include <cvirte.h>
#include <utility.h>
static int CtrlSlide=0, StyleIndex=-1;
static int AuthorizedStyles[]={        // Should work on all of those
        CTRL_NUMERIC_THERMOMETER,
        CTRL_NUMERIC_TANK,
        CTRL_NUMERIC_GAUGE,
        CTRL_NUMERIC_METER,
        CTRL_NUMERIC_KNOB,
        CTRL_NUMERIC_DIAL,
        CTRL_NUMERIC_VSLIDE,
        CTRL_NUMERIC_HSLIDE,
        CTRL_NUMERIC_FLAT_VSLIDE,
        CTRL_NUMERIC_FLAT_HSLIDE,
        CTRL_NUMERIC_LEVEL_VSLIDE,
        CTRL_NUMERIC_LEVEL_HSLIDE,
        CTRL_NUMERIC_POINTER_VSLIDE,
        CTRL_NUMERIC_POINTER_HSLIDE,
        CTRL_NUMERIC_THERMOMETER_LS,
        CTRL_NUMERIC_TANK_LS,
        CTRL_NUMERIC_GAUGE_LS,
        CTRL_NUMERIC_METER_LS,
        CTRL_NUMERIC_KNOB_LS,
        CTRL_NUMERIC_DIAL_LS,
        CTRL_NUMERIC_LEVEL_VSLIDE_LS,
        CTRL_NUMERIC_LEVEL_HSLIDE_LS,
        CTRL_NUMERIC_POINTER_VSLIDE_LS,
        CTRL_NUMERIC_POINTER_HSLIDE_LS
static char* StrStyles[]={
        "THERMOMETER",
        "TANK",
        "GAUGE",
        "METER",
        "KNOB",
        "DIAL",
        "VSLIDE",
        "HSLIDE",
        "FLAT_VSLIDE",
        "FLAT_HSLIDE",
        "LEVEL_VSLIDE",
        "LEVEL_HSLIDE",
        "POINTER_VSLIDE",
        "POINTER_HSLIDE",
        "THERMOMETER_LS",
        "TANK_LS",
        "GAUGE_LS",
        "METER_LS",
        "KNOB_LS",
        "DIAL_LS",
        "LEVEL_VSLIDE_LS",
        "LEVEL_HSLIDE_LS",
        "POINTER_VSLIDE_LS",
        "POINTER_HSLIDE_LS"
int CVICALLBACK cb_TestSRP (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_RIGHT_CLICK: DoSomething(panel, control); break; } return 0; } int CVICALLBACK cb_QuitSRP (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_COMMIT: QuitUserInterface (0); break; } return 0; } int CVICALLBACK cbp_Change(int panel, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_LEFT_DOUBLE_CLICK: if (CtrlSlide!=0) DiscardCtrl (panel, CtrlSlide); CtrlSlide = NewCtrl (panel, AuthorizedStyles[(++StyleIndex)%(sizeof(AuthorizedStyles)/4)], "", 50, 80); SetCtrlAttribute (panel, CtrlSlide, ATTR_CALLBACK_FUNCTION_POINTER, cb_TestSRP); SetCtrlAttribute (panel, CtrlSlide, ATTR_LABEL_TEXT, StrStyles[StyleIndex%(sizeof(AuthorizedStyles)/4)]); return 0; // Change it to 1 and there's no problem } return 0; } int main (int argc, char *argv[]) { if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */ int Pnl = NewPanel (0, "Test slide popup", 100, 100, 300, 300); int CtrlQuit= NewCtrl (Pnl, CTRL_ROUNDED_COMMAND_BUTTON, "QUIT", 0, 0); SetCtrlAttribute (Pnl, CtrlQuit, ATTR_VISIBLE, 0); SetCtrlAttribute (Pnl, CtrlQuit, ATTR_CALLBACK_FUNCTION_POINTER, cb_QuitSRP); SetPanelAttribute(Pnl, ATTR_CLOSE_CTRL, CtrlQuit); SetPanelAttribute(Pnl, ATTR_CALLBACK_FUNCTION_POINTER, cbp_Change); cbp_Change(Pnl, EVENT_LEFT_DOUBLE_CLICK, NULL, 0, 0); DisplayPanel(Pnl); RunUserInterface(); return 0; }
(3,555 Views)
Accepted by gdargaud
The problem can be 'solved' reading the help Smiley Wink :
You cannot discard a control in the callback function for the control, except when responding to the EVENT_COMMIT event. Discarding the control from its own callback function in response to other events might cause unpredictable behavior.
(3,554 Views)
You may try use PostDeferredCall function for this purpose
(3,551 Views)
OK, I wasn't too surprised about the control callback crash, but a little bit more when it happened in the panel callback...
(3,547 Views)
