LabWindows/CVI
Difference between fp and lfp files ?
I just discovered some *.lfp files. I'm not familiar with them and a quick
search did not reveal what they are. What's the difference with the usual fp
files ? An fp that embbeds a lib maybe ?!?
Guillaume Dargaud
http://www.gdargaud.net/
"Anti-glare screens to prevent eye strain ??? In my day, you didn't need
an anti-glare screen. With the power they consumed, when you turned your
computer on, the whole building darkened !" - Simon Travaglia (the
B.O.F.H.).
(3,661 Views)
Guillaume,
The .lfp format is an extension to the .fp format that is used by NI-supplied libraries, (such as all the CVI libraries that show up in your library menu when you start up CVI. You can see the files in the CVI\bin folder). Roughly speaking, it stands for "Library function panels". The only two differences between an .lfp and an .fp are:
1. An .lfp is not editable in the Function Tree Editor.
2. An .lfp takes advantage of linked help. In a typical large library, many functions and parameters share the same help content. By allowing these to be linked from a master copy of the help, it reduces the overall size of the file greatly.
There is no difference in their relationship to the corresponding program module (.c, .obj, .lib).
Luis
(3,646 Views)
