04-09-2018 10:30 AM
Hello experts,
I have an application created with LabWindows/CVI and released in production. I configured the OS so that a core dump is created every time the application crashes.
In order to use analyze the dump file in a profitable way I need the symbols file for my application.
Does anyone know how to create the symbol file in LabWoindows/CVI?
Alternative ways to analyze production application crashes are welcomes of course.
Thanks in advance
Regards
04-09-2018 10:37 AM
I suggest you to enable Generate Map File option in Build >> Target Settings: this will create the memory map of the application that you can compare with info in the crash dump to locate the function where originated the error.
04-11-2018 03:54 AM
Thanks Roberto,
that's a valuable suggestion.
Best Regards
