LabWindows/CVI
DRIVER ODBC FOR WIN2000
I have actually a programm compiled with cvi5.5 running under win95.
It use a mirosoft access database, and i want change win95 for win2000.
Now (with win2000), I have a problem with the fonction DBCONNECT :
the execution return always the code -99 (Database Dll could not be loaded).
Before, under Win95, I used the driver cvi_db.fp with cvi_db.h and cvi_db.lib
I think that this driver may be compatible only with Win95 and WinNT.
Question : Is there a version of this driver compatible with Win2000?
rem: If i don't want to remake all the code, I need a version whith the same functions...
Thanks..
(2,931 Views)
Hello Fred64,
You can found, in the link below, a new version of ODBC driver for Windows 2000 :
http://digital.ni.com/softlib.nsf/websearch/2776e9b9ea99049b862569c2006604df
Please, see also the link below that can help you to solve your problem :
http://forums.ni.com/ni/board/message?board.id=170&message.id=43068&requireLogin=False
Hope this help.
Sanaa T
National Instruments France
Sanaa T.
(2,903 Views)
