10-06-2011 08:08 PM
If my PXI-4065 is executing a niDMM_ReadMultiPoint call, is it possible to call niDMM_Read (or some other function) from another thread and get the latest value read by the DMM while the ReadMultiPoint is executing? It seems if I call niDMM_Read from another thread, it waits until the ReadMultiPoint completes before it executes.
10-07-2011 10:33 AM
Hi gstemp,
Thank you for posting on the forums. Unfortunately you will not be able to perform these reads and the same time, the 4065 only has 1 Analog to Digital converter so you can't make 2 measurements at the same time. You could either do a multipoint read and take lesss points so it updates faster or take a single point read and use and loop to continously aquire the data. I know that this is not ideal for your situation but what you are trying to do is not actually possible with a DMM.
I hope that helps,
Brian P.
