LabWindows/CVI
DLL error 126 on a DLL using NI-Visa LabWindows 2020
I’m working on a project where I need to use a DLL useful for reading and writing to serial port.
I tried in every way to call the DLL through a server I wrote, always using LabWindows, but with the LoadLibrary command I get the error 126, that is "module not found".
In the various attempts at correction I have already tried to :
1) DLLEXPORT
2) Create a new project
3) Debugging in 32 and 64 bits
4) Check that the server worked with a DLL with only one print function (and it works)
5) Create a separate folder so you don’t have names that could create a conflict in the file search
6) Updated NI-Visa to version 21.5
Even searching online I do not understand what is wrong with my code because according to what I found in this community, it should work.
I am patiently waiting for someone to give me a hand in finding the solution to this mystery and I appreciate your answer ahead of time.
(3,530 Views)
I don't understand your reference to VISA when you say you are trying to use a DLL.
If it's VISA functions you want to use, then you do not need to directly access the DLL: if VISA is installed in the system you'll find its functions in  the Library menu.
Alternatively you could simply try using built-in RS232 functions.
Or you may actually need to call that specific dll, in which case please add some detail more.
(3,514 Views)
If you have Visual Studio, you can use dumpbin to check if your required function is exported by the DLL.
dumpbin /exports filname.dll
(3,480 Views)
Who created that "useful" DLL?
With what compiler and version?
Was it compiled as release version?
With C Runtime library as external dependency or compiled into the DLL?
Rolf Kalbermatter  My Blog
(3,419 Views)
