LabWindows/CVI
DAQmx calls to set up the NI-9361 Counter Module??
Win10, CVI2019.
I want to use the NI-9361 Counter/Timer Module to measure frequency.  Anyone there have an example of the DAQmx calls to set up this module or one of the other Counter/Timer modules?
Or is there a document out there?
Thanks...
(618 Views)
You can refer to the example vi in LabVIEW.
In LabVIEW, go to Help -> Find Examples. Once you have launched the NI Example Finder, look for the example vi under Hardware Input and Output -> DaQmx -> Counter Input -> Counter - Read Pulse Duty Cycle and Frequency (Continuous).vi
Hope this helps.
(608 Views)
