you are right, looks like the control does not behave correctly when the data is pasted to the control. I'll submit a report on this. In the mean time, you can modify the code to take into account this special case. You can find the code at C:\Program Files\National Instruments\CVI70\toolslib\custctrl\pwctrl.c
Another option is to create a callback for the control and catch the keyboard events; check if the user pasted something and probably swalow the event by returning a non-zero value; this should avoid the text to be pasted.
I hope this helps.
Juan Carlos
N.I.
