04-11-2018 09:02 AM
04-11-2018 09:20 AM
I think a good starting point if you are new to CVI is to use the menu Help / Find Examples and the search keyword "graphs". This search will yield many examples, e.g., graphs.cws that demonstrate how to use graphs.
04-12-2018 03:00 AM
Hello
thks for replaying , now i create this interface that can :
acquire image read the caracter (number ) using ocr
after that i display a graph its an histogram who affiche number on object ans effort applying in each objetc
but i have probleme with the displaying on bare on right (plot 1 plot2 ......) its debord and i want to stop it on each plot and to synchronise without displayin all the plot
view the pic bellow
thks for helping
04-12-2018 03:14 AM
Hi, I had a look at your picture - but I do not understand your text below...
its debord
...what do you want to display and stop?
@Bylka wrote:after that i display a graph its an histogram who affiche number on object ans effort applying in each objetcbut i have probleme with the displaying on bare on right (plot 1 plot2 ......) its debord and i want to stop it on each plot and to synchronise without displayin all the plot
04-12-2018 03:21 AM
thank you for answering I did not express myself well
in the right bar where I circled in blue the histogram takes data from an array and then on the bar or is written plot ..... does not stop it displays and overflows I would like to disable it
04-12-2018 03:34 AM
so you are talking about the graph legend?
if so, why does the legend show 24 green plots, the histogram only 6? Could it be that you add a new plot for every data point instead of replacing the old plot (delete and plot again)? Still, I am afraid that I did not really understand your issue...
04-12-2018 03:42 AM
Because on x axis it show number of stud (bolt) after that we apply an effort so the histogramme take a defferent values of array on each bolt it s why the legend of plot change and on graphe its steel fixed by user numgoujonValue 6 or 4 ..;
04-12-2018 04:01 AM
i found how to disable it
now i have other problem on my code can you help me on it i have to make some change on it
thks
