‎06-27-2011 10:29 AM
Three years ago I wrote a CVI application for an Environmental Test that was COMPLETELY standalone. NO Network, PC only, NI USB DIO box and Unit Under Test (UUT) and it ran for 24 hours at a time. The problem is that after adding some additional functions in CVI V9.0 the application only runs seven minutes and stops. I cannot remember what needs to be done once the application is delivered to make it run for 24 hours. Any help would be appreciated. It was really simple.
‎06-27-2011 10:47 AM
If you have created the executable in a evaluation version of CVI it will only run for a few minutes and then simply stop. You possibly have not converted your CVI 9 evaluation install into a full install: check with NI to have the necessary authorization code for the product.
‎06-27-2011 11:03 AM
It used to be that the run time engine had to connect back to a license server every so often even if you have a FULLY activated license.
‎06-27-2011 11:10 AM
Are you sure? I never heard about something like that! I have plenty of applications installed on customers' sites that do not connect to any licence server to run.
May it be that some other piece of software / driver needs that connection?
