LabWindows/CVI
Code refactoring: "include-what-you-use" tool
Code refactoring is a common need for C developers and availability of eiter automated or semi-automated tools can be really helpful.
Since LabWindows/CVI now uses llvm+clang, probably a tool like "include-what-you-use" can be integrated.
This is the github page for the tool.
From the documentation:
"Include what you use" means this: for every symbol (type, function variable, or macro) that you use in foo.cc, either foo.cc or foo.h should #include a .h file that exports the declaration of that symbol. The include-what-you-use tool is a program that can be built with the clang libraries in order to analyze #includes of source files to find include-what-you-use violations, and suggest fixes for them.
The main goal of include-what-you-use is to remove superfluous #includes. It does this both by figuring out what #includes are not actually needed for this file (for both .cc and .h files), and replacing #includes with forward-declares when possible.
Is this tool available in CVI?
If not, I can open a new suggestion in the Idea Exchange Forum (if CVI is actively developed - I have some doubts Smiley Sad)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(5,308 Views)
I certainly will support your suggestion Smiley Happy
(5,306 Views)
I will support it as well
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(5,291 Views)
Accepted by vix
Here you can find my suggestion in Idea Exchange forum.
Feel free to give your kudo if you support the idea.
Vix
Using LV from 7
(5,277 Views)
