LabWindows/CVI
Can I create a merge module (.msm) in LabWindows/CVI 2010?
Is it possible to create .msm files in LabWindows/CVI 10?  If so could someone just point me in right direction please?  Thank you.
(3,243 Views)
Accepted by TotalAJ
You can't create merge modules in CVI but you can consume merge modules in our distribution builder. Normally, if you needed to create a merge module, you would create the merge module in a tool like WiX and then consume it in CVI. Just out of curiosity, what exactly are you trying to do?
Jonathan N.
(3,241 Views)
Thank you for the answer.
I am building a number of DLLs that could be used independently in which case i would not use msm, .  For this particular project however I would be installing all the libraries and would like just one install package that would install all the libraries.
(3,219 Views)
