LabWindows/CVI
CVI crashes after installing VISA 5.0.2 driver
I am using CVI 2009 evaluation version for creating applications using VISA interface. First time when application is executed with real hardware connected to the PC, it showed an error "A code library required by VISA could not be located or loaded". Then i installed NI-VISA 5.0.2 driver downloaded from NI site. From then onwards if i try to build or run the application, CVI is getting closed. But other sample programs are working fine.
Could any once provide solution for this.
Thank you,
Divya
Message 1 of 1
(2,829 Views)
