LabWindows/CVI
CVI SQL TOOLKIT : Fetching records with Interbase/Firebird stored procedure.
Hye.
I want to fetch records from a Interbase/Firebird stored procedure.
I know how to execute a stored procedure that just returns a return code. I have test this and it works.
The stored procedure just done a SELECT command on a single table and return records. It does'nt have input parameters just an smallint output parameter named 'idcentral'.
This is the text of my stored procedure :
begin
for
 select ID_CENTRAL
 from Centralisateur
 into :"IDCENTRAL"
do
  suspend;
end
Note : ID_CENTRAL is a smallint type column
          idcentral is a output parameter
I Just want to read the return records in my CVI application. This is the code :
short idCentral = 0;
   resCode = DBSetAttributeDefault (db_handle, ATTR_DB_COMMAND_TYPE,DB_COMMAND_STORED_PROC);
   hstmt = DBPrepareSQL (db_handle, "PR_SELECT_CENTRAL");
   resCode = DBSetAttributeDefault (db_handle, ATTR_DB_COMMAND_TYPE,DB_COMMAND_UNKNOWN);
   /* Refresh the parameters from the stored procedure. */
   //resCode = DBRefreshParams (hstmt);
   resCode = DBCreateParamShort(hstmt, "central", DB_PARAM_OUTPUT, idCentral);
   resCode = DBExecutePreparedSQL (hstmt);
   while ((resCode = DBFetchNext (hstmt)) == DB_SUCCESS)
    /* Lecture valeur colonne 1 du record courant. */
    resCode = DBGetColShort (hstmt, 1, &idCentral);
   // Pour libérer des ressources proprement
   resCode = DBClosePreparedSQL(hstmt);
   resCode = DBDeactivateSQL(hstmt);
Is this the right way to fetch the records as results ?
I use the refreshparams() function but it does'nt work best.
Could you help me or give me links to Internet sites.
thanks.
(3,652 Views)
OK!
It was a problem on the EASYSOFT ODBC Driver.
I have selected a bad option.
(3,629 Views)
