LabWindows/CVI
CVI PlotY: How to center the X-axis at zero?
Dear colleagues,
I have a simple (maybe stupid) question about graphs in NI CVI.
My graph is “symmetrical” (it’s a simple PlotY graph where the X-axis is shifted by an offset), and I would prefer to have zero displayed in the middle.
Which attribute can I use to adjust this:
I tried adding a cursor at the zero position and played around with the attributes all morning, but that didn’t help.
Any idea how I can fix this and make it look perfect (in generic way, the range could be differ from run to run)?
Thank you in advance.
(1,389 Views)
It appears as if your graph is in autoscale mode in the X-Axis. If this is true, then you could try setting it to manual mode, calculate the appropriate range and set it to the axis before plotting the values.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(1,358 Views)
Looking at your first picture, I suppose the value of 2 in the middle depends on some rounding on actual values. You could probably fix it with this code:
// Calculate actual range
MaxMin1D (array, nElements, &maxVal, &maxIdx, &minVal, &minIdx);
// Round to the next group of ten
max = Max (ABS_VAL (minVal), maxVal);
max = (ceil (max / 10.0)) * 10.0;
// Apply the range to the graph X-axis
SetAxisScalingMode (panelHandle, PANEL_GRAPH, VAL_BOTTOM_XAXIS, VAL_MANUAL, -max, max);
Max and ABS_VAL macros are part of the Programmer's Toolbox, defined in toolbox.h.
(1,291 Views)
Yes, I've already tried rounding to the next multiple of ten, and sometimes it works (though not always; I think I've seen the same behavior even with rounding). I'll check a few different scenarios.
(1,281 Views)
Accepted by Andrey_Dmitriev
I asked google AI how to set the x markers
void InitializeSymmetricGraph(int panel, int control, double n) {
    SetAxisScalingMode (panel, control, VAL_BOTTOM_XAXIS, VAL_MANUAL, -n, n);
    // 10 Intervals create 11 ticks, 6th tick is at 0.0
    SetCtrlAttribute (panel, control, ATTR_XDIVISIONS, 10);
Disclaimer: I have no LabWindwos/CVI installation, so I can not verifiy if this will work or if these parameters are real. I had to ask AI if ATTR_XNUM_DIVISIONS is correct, which obviously is not.
At least there is a help entry for ATTR_XDIVISIONS: https://www.ni.com/docs/de-DE/bundle/labwindows-cvi/page/cvi/uiref/cviattrxdivisions.htm
(1,259 Views)
Yes, thank you, that does the job. It is exactly the attribute I was looking for. I was sure something like it existed for the scale, but I overlooked the Divisions setting. Sometimes I can't see the forest for the trees:
(1,224 Views)
