LabWindows/CVI
CVI Build of Lua
Does anyone know if Lua has been built in CVI?  I am looking for an embedded script engine and Lua looks rather promising.
TEDoyle
Message 1 of 14
(7,686 Views)
TEDoyle,
I don't know of anyone who has built Lua in LabWindows/CVI here at NI, now that doesn't mean no one ever has, but we do not have any documentation on such a process.  I took a brief look at the source code available from the official Lua website, and it seems like you should be able to compile it in CVI as long as there isn't any code that conflicts with the ANSI 89 standard to which CVI's compiler is compliant.  If you simply want to use Lua in CVI then that should be no problem since it has a built-in C API that you should be able to call from CVI.
John B.
Message 2 of 14
(7,650 Views)
John,
 I tried to build Lua within CVI but ran into some problems.  There are a few functions (e.g. _popen and _pclose) that are not directly supported.
TEDoyle
Message 3 of 14
(7,633 Views)
TEDoyle,
I have compile and embedded LUA in CVi with succes.
No real problems nor tweaks.
Message 4 of 14
(7,630 Views)
Would it be possible to get a copy of your project so I can give it a try?
Message 5 of 14
(7,628 Views)
I join zip file of folder with cvi prj and cws.
Message 6 of 14
(7,625 Views)
Previous post was the project for creating the luacvi.lib, here is a small quick and dirty test project.
Message 7 of 14
(7,623 Views)
Thanks!  Works great.  Which version of Lua is this?
Message 8 of 14
(7,615 Views)
It's version 5.1.3
Regards
B.Williot
Message 9 of 14
(7,612 Views)
Thanks again!  I am working on an embedded CVI-RT project and I need on a embeddable script engine.  Lua looks to be a good candidate.
TEDoyle
Message 10 of 14
(7,610 Views)
