11-17-2008 04:50 PM
11-24-2008 01:13 PM
Hi eatmontr,
I searched for this file on my computer and was unable to find it. Are you perhaps referring to toolbox.c? It seems like the easiest way to do this would be to rename the 8.0 version of the file to something like "toolbox.bak" and replace it with your customized toolbox file. Hope this helps!
11-25-2008 10:11 AM
Also, if it is in fact toolbox.c, it's not mandatory that CVI always include its own toolbox.c each time it links a project. To remove it, select Library>>Customize, and then remove toolbox.fp from the list of user libraries. Once you remove it, and you restart CVI, you can then add your own customized version of toolbox.c to your project without having a link conflict.
Luis
