LabWindows/CVI
CA_FreeMemory Breaks without a breakpoint set.
The functions CA_FreeMemory is breaking every time I call it even though I don't have a breakpoint set. Does anyone know of this problem? Is there an alternate function that can be used to free the memory that doesn't break whenever called?
(3,037 Views)
Hi Steve,
This KnowledgeBase article describes the issue you are seeing: Missing Breakpoint in LabWindows/CVI Code.  Another function you can use to free memory is the ANSI C function free (found in stdlib.h)
Eric B.
(3,015 Views)
