04-06-2021 08:47 PM
Hi all
I want to use NI 9481 4-Channel C series Relay Output Module in C++ and for this purpose, i need C APIs (Just like there are C APIs for ADCs, DACs etc) to access & control this module.
Kindly guide me where i can find them?
Thanks & Regards
04-18-2021 09:28 AM
In what kind of chassis do you use this module? If it is a cDAQ module, I would suggest you take a look at the DIO functions in DAQmx. If you rather use it in a cRIO chassis, then you would need to look into the C API for NI-RIO software, but I have no experience there.
05-11-2021 11:08 PM
Hi
I am using it in cDAQ module
