09-27-2017 09:28 AM
Hi JPipe,
please do not keep the same discussion alive on two threads!
You already opened a discussion on this very specific item so please keep all posts there so that the argument can be evaluated by all participants together.
02-09-2018 04:34 AM
I genuinely thought CVI was dead, NI have put less effort into promoting it than I've put into signing up on here. Easily the simplest and most powerful one-box C&I solution. L....W? Let's not go there 😄
02-09-2018 07:50 AM
CVI is still going strong - new improvements are in development and existing bugs are being fixed. I expect that will be the case as long as people are writing test code in C
~Trent
02-20-2018 03:25 AM
Hello I am a beginner on labwindows software and i'm on project that i have to aquir and processing an image if that's possible to help me thanks friends
02-20-2018 09:49 AM
Hello rosoo,
this thread is only intended for announcement of a new CVI release, not for answering specific questions.
Please create a new discussion with your question, and while doing so be sure to add all relevant informations like for example the CVI release in use, additional tools you are intending to use (e.g. the Vision Assistant module) and the type of cameras you want to use, otherwise is difficult to try helping you.
02-21-2018 02:37 AM
Hello Roberto thank you for your relay yes i was create a new discussion
^^ have a nice day
