LabWindows/CVI
Announcement: LabWindows™/CVI™ 2015 SP1 f1 Patches
Critical updates for the LabWindows™/CVI™ 2015 SP1 Development Environment and the LabWindows/CVI 2015 SP1 Run-Time Engine have been released. Note: These are two separate patches.
  • The LabWindows/CVI Runtime 2015 SP1 f1 Patch is strongly recommended for all users of LabWindows/CVI 2015 and 2015 SP1.
  • The LabWindows/CVI 2015 SP1 f1 Patch is recommended for users of LabWindows/CVI 2015 SP1 who distribute applications for Windows XP.
You may obtain the update using NI Update Service or by using the associated download page on ni.com/downloads. You may find the list of issues fixed by the update in the LabWindows™/CVI™ 2015 SP1 Patch Details.
Trent Weaver
Automated Test Software PSE
Message 1 of 16
(6,512 Views)
Hi Trent
Can you clarify the following note:
How I can generate an XP installer? I don't see XP in the "Minimum operating system version" list in Advanced tab of "Edit Installer" dialog. May be using this trick?
Carlo A.
Megaris
Message 2 of 16
(6,479 Views)
Carlo,
Yes - the KB you pointed out is accurate for CVI distributions built after installing this patch. Since XP isn't officially supported in 2015 SP1, you cannot select it as a minimum OS version for distributions.
-Trent
Message 3 of 16
(6,478 Views)
Trent, is there a way to programmatically understand if the RTE has been patched or not? GetCVIVersion still returns 1501 and GetCVIVersionYear simply state 2015...
Message 4 of 16
(6,456 Views)
Smiley Happy This has been suggested some time ago and the idea is even under review - so maybe in the future we will be able to find out easily (not having to use registry ...)
Message 5 of 16
(6,456 Views)
Wolfgang, no need to use registry, only a function from Version.Lib.
beware: this is quick & dirty code, just tested only on my PC. It prints version info in the passed string.
int GetCVIRTEVersion(char *s)
char sFile[MAX_PATHNAME_LEN+1];
unsigned int iBufferSize,iDummy;
char *pBuffer;
VS_FIXEDFILEINFO* fixedVerInfoPtr;
int iVer[4];
unsigned int len;
// CVIRTE is obviously already loaded...
   GetModuleFileName(GetModuleHandle("CVIRTE"), sFile, MAX_PATHNAME_LEN + 1);
// get size of version info (0 if no version info exists)
    iBufferSize = (unsigned int)GetFileVersionInfoSize(sFile, (LPDWORD)&iDummy);
    if (iBufferSize > 0) {
        pBuffer = malloc(iBufferSize);
// get fixed file info (language independent)
        GetFileVersionInfo(sFile, 0, (unsigned long)iBufferSize, pBuffer);
        VerQueryValue (pBuffer, TEXT("\\"), (LPVOID*)&fixedVerInfoPtr, &len);
        // read version blocks
        iVer[0] = HiWord(fixedVerInfoPtr->dwFileVersionMS);
        iVer[1] = LoWord(fixedVerInfoPtr->dwFileVersionMS);
        iVer[2] = HiWord(fixedVerInfoPtr->dwFileVersionLS);
        iVer[3] = LoWord(fixedVerInfoPtr->dwFileVersionLS);
        sprintf(s,"%d.%d.%d.%d",iVer[0],iVer[1],iVer[2],iVer[3]);
        free(pBuffer);
    return 0;
Carlo A.
Megaris
Message 6 of 16
(6,451 Views)
I tried to install this patch on a PC with W7 Pro 64 bits but got an error that the patch is not compatible with my OS.
Is this normal? I couldn't find any explanation for which OS this pacht is compatible.
Bertrand
Message 7 of 16
(6,105 Views)
Both the LabWindows™/CVI™ 2015 SP1 f1 Patch and the LabWindows™/CVI™ Runtime 2015 SP1 f1 Patch should be compatible with Windows 7 based on the Operating Systems listed on the download pages linked. What is the error that you're getting exactly?
Mathew H.
Applications Engineer
Message 8 of 16
(6,085 Views)
Message 9 of 16
(6,074 Views)
I saw a similar error, in the past, when attempting to install a program in a XP machine that was not updated to the latest patches.
Is your Windows 7 fully updated, to SP1 mainly and with the following patches?
Carlo A.
Megaris
Message 10 of 16
(6,071 Views)
