10-17-2017 10:51 AM
Hi all,
I made an application with Labwindows/CVI and I would like to add a license to restrict the access of it.
Is it possible ?
Thanks for your reply
Solved! Go to Solution.
10-19-2017 08:56 AM
Hi jo24,
I am not aware of any licensing options when building your application using CVI, besides the license agreement file.
You can take a look at this article regarding the deployment and distribution of applications using CVI Distribution Kit:
http://www.ni.com/white-paper/5987/en/
If there is a way to implement licensing in your application, you would have to use an external code/program to manage the license generation and distribution.
10-25-2017 01:41 AM
