LabWindows/CVI
看到一个非常好的XY图表显示,这个是怎么实现的呢,每条曲线一张图片,求指导
  1. If you can, try posting in English in this international board, otherwise post to the most appropriate board found under Regional Communities
  2. I don't understand your question, please add some detail more on your requirements: where data come from (memory, file -which type?-, instruments...), if you want only to represent actual data or need some operation (e.g. smoothing/filtering...) and other details that may help us to help you. Last but not least, confirm that you are using LabWindows/CVI
(1,827 Views)
数据是通过网络分析仪读出来的,是想让它以图表的方式显示出来,便于判断芯片的指标是否正常
(1,813 Views)
Ok, let's hope Google does a good job in translating...
Are you creating this application using CVI? I'm asking this 'cause I see that you have already posted questions related to the LabVIEW environment. Now, if you are working in LV this is the wrong board and I cannot help you; if on the contrary you are working in CVI you can use graph-related functions like for example PlotXY or PlotWaveform, depending on how your data are structured.
(1,810 Views)
CVI中工作,则可以使用与图形相关的功能,例如PlotXY或PLOT波形,具体取决于数据的结构。,可否给一个VI怎么实现呢,thanks
(1,808 Views)
Sorry, I can't help you with LabVIEW: I've not been using it in the last 15 years!
(1,804 Views)
