08-24-2014 08:32 PM
本人通过CVI自带的工具制作的软件安装包,但是安装时无法自动生成桌面快捷方式,求助,谢谢!
08-25-2014 12:49 AM
You can find a detailed explanation of how to distribute CVI applications here, or use the help of the Edit installer Dialogue Box - Shortcut Tabs:
Use the Shortcuts tab located in the Edit Installer dialog box to create shortcuts for the files you install.
New Shortcut—Create a new shortcut by right-clicking on the Name column and select New Shortcut from the menu.
