LabWindows/CVI Idea Exchange
Wolfgang
status bar control
Over the years the look of CVI's control elements got closer to native Windows controls, e.g. by the direct use of native Windows controls such as the File Select Popup, which I would consider a welcome visual improvement.
What still is not available is a control element providing a Windows-like status bar, e.g. like the one of CVI's IDE.
I imagine a status bar which is similar to use as a menu bar, i.e. with a LoadStatusBar command, similar editing capabilities and the possibility to define the number and type of elements (text, image,...). Also the lower right part should resemble the typical Windows 'triangle', see figure below.
Thanks!
1 Comment
LuisG
NI Employee (retired)
Status changed to: Under Consideration
