LabWindows/CVI Idea Exchange
CVI-User
WYSIWYG UIR Editor (again)
Status: New
Please make the UIR editor WYSIWG again.
It's difficult to size and position controls if they get a (slightly) different size when the program is run because they use an other font than the editor.
See example here.
If you can't, at least make the editor use the same replacement as the runtime.
/* Nothing past this point should fail if the code is working as intended */
