LabWindows/CVI Idea Exchange
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Top Kudoed Authors
OPC UA
Network Variables currently provide support for OPC DA. However, the industry has been moving from OPC DA to OPC UA (Unified Architecture). The reasons for this are many, but mainly based on security and ease of use. Surveys over the last couple of years show that there are now more devices and applications being produced with OPC UA support than DA support. I have enquired whether NI are planning to support UA technology, but it seems that this is not in the pipe line.
There are solutions available (open62541, for example) that may provide a solution. Does anyone have any experience with using this solution with CVI?
I am looki
1 Comment
Proven Zealot
This sounds as a question rather than a product suggestion. I suggest you to look into CVI forum board, where some threads on OPC UA and open62541 can be found, and comment/post there if you have specific questions.
