Ni.com is currently experiencing issues that may cause some pages to fail.
Support teams are actively working on the resolution.
If you select an User Interface control you can move it to a new location in two ways:
Using the arrows is an easy way if you want to move the control of a little quantity, but it's difficult if you need for example 200 or more pixels.
Moreover with Arrange >> Control Coordinates you can set the new location for a group of selected controls using the "All" buttons.
But if you want to move a group of controls of a desired offset you can only use the arrows.
I suggest the implementation of specifying either an absolute position or an offset throug the Control Coordinates window, both for a single control and for a group of them.
