It would be nice if eventData1 and eventData2 were used when EVENT_VAL_COERCED is triggered.
I have an application in which I want to know if too high or low of a number entered.
GetCtrlVal always returns the coerced to number that is in range.
if eventData1 is 1 the max value was hit, if -1 the min value was hit.
eventData2 is always 0.
You can check the value returned by GetCtrlVal against the min and max of the control using GetCtrlAttribute.
I am running into an issue where my ranges change based on other control ranges and sometimes the min and max of a control are set to the same
number. I want to know if the number entered was too high or low.
