When attaching a graph to a splitter control where the splitter control sizes the graph, I've noticed a few things.
1. First, the legend is also attached to the splitter so that it moves. This works well if the legend is located in the default location (at the bottom right corner of the graph control) but problematic when the legend has been located elsewhere. I would like the option of having the legend move or not move when the graph control is attached to a splitter that sizes (I would imagine this might have to be a new graph control attribute).
2. In addition, it would appear that the label is not attached to the splitter so it doesn't react to the splitter control being operated. It would be nice if there was some way that the label text could be attached to a splitter, or perhaps a setting so that the label text could be made to auto-center above the graph control when the graph control is resized by the splitter. (a potential workaround for the moment is to not use the label with the graph control and instead use a text message control as the label that can then be attached to splitter controls independent of the graph itself).
Thanks.
