Not a big deal in my point of view...
However, the name of the project in the workspace tree has a first letter capitalized (upper case)
See below the screen capture
This may not be what the user want to see
This is purely cosmectic since opening the cws or the prj file with a text editor one can see the workespace/project use the correct name (no upper case letter)
The only solution so far is to manually go to Edit then "Project.." and modify the project label
Does it make sense?
Regards, Philippe
